youtu.be/9rtiFBC0wms
Burgerman wrote:If those threads in the cells were crap, used, not deep enough I would return them. If not, I would likely helicoil all of them from te start. You can buy tangless ones too. No hammering. Use a drill press, be sure you TAP them in a drill press by hand turning to be sure its straight. Use green thin loctite. THEN build pack better than new. I used to do this on bikes every time I built a motor. Better stronger threads than new.
Update from the supplier.
He said I can drill them ok, but don't go deeper than 7.5mm.
So that's my next job
Burgerman wrote:Update from the supplier.
Thats not enough. ANY blind thread must be 9mm deep minimum or its bad by design.
You need 9mm of thread minimum as thats 1.5x diameter. That means drilling 11mm and tapping with a bottom tap to 9mm.
And all the thread repair helicoils will be 9mm tall. https://uk.rs-online.com/web/p/thread-r ... s/0528659/
LROBBINS wrote:Drill size for an M6 helicoil is 6.2 mm. In soft aluminum you might get away with running a tap directly in the already tapped (and partially stripped) threads, but it might be safer to get a 6.2 mm bit and carefully drill first. M6 helicoils do come in 1d length too, but probably harder to find than 1.5d or longer. John is absolutely correct that you can't use a hand drill and even tappin is best done with a drill press (but by hand). You must turn it by hand (unless you have a fancy adjustable torque tapping machine) so you can feel when the tap just touches bottom.
Although the Al is soft, it's probably best to turn a bit and then back off the tap to break the chip, then turn a bit more etc. Perhaps if you've not done this before you can practice with a scrap piece of aluminum before risking the cells. Candle wax is a reasonably good lubricant for aluminum, but you'd need to clean it out with solvent if you use it. Aluminum is easy; if you tap stainless without breaking the chip often and best using a lubricant even for hand tapping, you'll break a few taps before you get a feel for it. Brass also tends to bind, but taps very cleanly if you're careful. Ever try removing a broken M3 tap from a blind hole? (For "large" sizes like M6 one can get removal tools for getting out broken taps - they have thin fingers that go down the flutes. I don't own any, but the machine shop where I learned to properly tap things did, and I've never seen one for M3.
. (bigger cordless are too heavy for little 'ol me). https://www.ebay.co.uk/p/Bosch-GSB10-8- ... /215580665
i dont understand all you mentioned - never used or know what a spanner is - etc, i am just trying to figure out options - which would be best - Green Loctite - is still removeable ? - only wrench i have for the headways are 5nm -
i would rather use allen head bolts and do it right into the cell as intended - but if there are issues from that -
then the grub screw way was my second choice - giving i have the room - i didnt factor that in - never intended to use grub screws etc, may not be able either way - i have 1 1/2 inch of room - for wiring - has to be same as MK Gel 9.5 high no more
i dont think they are 10mm deep the treads - i could be wrong - my screw i received is 10mm the part that gets screwed down -
but thats assuming you add the ring terminals and flat and lock washer as supplied - - if its a problem - then all these kind of cells will be a problem - other than the cells with the posts sticking up and screw nut down over it - instead of in it
sounds more complicated now - having to figure out the correct screw size - means trying a few screwing in and removing - risk stripping
Scooterman wrote:This is my drill Terry, it's been hammered but is still going strong, hopefully. (bigger cordless are too heavy for little 'ol me). https://www.ebay.co.uk/p/Bosch-GSB10-8- ... /215580665
But that's beside the point, why I mention it is that I looked for a drill stand for it but on checking out reviews, none were rated very highly. I did think of gluing a round 360 bubble level to the back end for vertical drilling, but didn't in the end, purely relied on eye (not great I do admit).
But one day I will buy a pillar drill either new or secondhand. I want a flat/house with a spare room or heated garage which I can kit out as a proper workshop instead of using a B&D workmate in the garden.
But if you buy a drill press let us know if it's any good.
Burgerman wrote:sounds more complicated now - having to figure out the correct screw size - means trying a few screwing in and removing - risk stripping
NO risk of stripping at all because you do all your trial and error, careful checking, making sure the bolts threaded part is long enouh but not too long, by screwing it together with your hands, finger tight! Only when you do this on every connection, and are sure that theres enough thread length, and that it tightens up correctly without bottoming in the hole, do you touch it wih a tool of any kind.
Its a bolt.Its not some kind of rocket science. You just need to take a little care with thread length on EACH SEPERATE TERMINAL by trying it with care, looking what is happening, before attacking it like some kind of ape with tools.
Scooterman wrote:You can always do this if enough headroom. Stud, locknut, washer,lug, washer,nut, locknut. Locknut is just a phrase, doesn't need to be nyloc a normal nut locks down fine.
Just a suggestion.....
(Bottom locknut anchors stud into place)
Burgerman wrote: attacking it like some kind of ape with tools.
terry2 wrote:
I can't find a stand for our drills, so I will have to go old style.
Get a bit of wood at least 2 inches thick.
With the drill you get in the helicoil kit, drill a hole as straight as possible.
This will be your guild![]()
Once my bad cell goes I will helicoil it and post pics.
Burgerman wrote:M4? Sounds dodgy! Might be OK if that aluminium alloy is hard enough. But it sounds a little small and weak to me.
Helicoils mean you end up with a M6 thread again, but it is steel/stainless steel.
Users browsing this forum: No registered users and 343 guests
