Burgerman wrote:THAT says:
Lead MK 73Ah + ADDON
So that wont work will it!
Its looking for the addon and the balance connector, and wants to charge a lithium!!!
You must slow down and read and absorb and be careful.
Your lithium is 8S...ADD ON and LEAD as on - using your new preset you made me - should i check that setting for the Cell count - ? what should be there ?
Burgerman wrote:ADD ON and LEAD as on - using your new preset you made me - should i check that setting for the Cell count - ? what should be there ? Your lithium is 8S...
Its set to AUTO correctly. It uses the balance cable to tell it how many.
Setting LEAD preset to 12 Cells means it will not charge a 12v battery. Only 24V. But AUTO is also good. Because your battery will not be over 13 (26) volts when you want to charge.
Ok i see - if i want to charge a 12V - i have to set it to 6 cells or auto - Auto didnt work ? was it because it was already charged enough ?
Burgerman wrote:Stop the lead charge. Its already charged.
Its safe now to fit the ADDON.
And charge now with the LEAD+ADDON preset. To see what it does. It wont give that error.
Burgerman wrote:Your lithium is 8S...ADD ON and LEAD as on - using your new preset you made me - should i check that setting for the Cell count - ? what should be there ?
Users browsing this forum: Bing [Bot] and 505 guests
