Burgerman wrote:Its what it says. You get that if it shuts the charge down for 101 reasons or if you choose a wrong cell count or a cell is under voltage, or if you have other problems with a previous charge.
shirley_hkg wrote:Received the PL8 , and find its balance port is small . Smaller than the connectors we usually have on the battery side .
Why not conform ! It's pointless .![]()
Is it a bad thing ? i dont see why i get them from the very first time in use - and each time i start it - nothing is done any different then when i use the first charger which dosnt do that ?
is this something i need to address somehow ? maybe i can reset the unit somehow ? or just try a firmware upgrade - it has the latest already -
Its maybe something to do with your 12v power supply or more likely an error on the previous charge? You dont need do anything.
shirley_hkg wrote:Ours are refurbised models and came in naked .
Looking for the balance connector . Just want to be sure of the right one .![]()
Would anyone please post a close up shot of this JST-PA 2.0 connector ?
Dont think its the PSU - dosnt do it with the first PL 8 and same PSU -
FMA - said i can try a software restore or reinstall the software - i did a firmware update - and factory restore - just to cross that off my list of things i tried - only thing left is the software - -
if not FMA says just Click no when i get the message - that i knew already - but want to make sure its working fine
last i remember there was a issue with the software - but it was fixed - do you know for sure the new software is working fine before i get rid of the current software -
Burgerman wrote:I did? I thought it worked fine and still did, and the new extra one didn't work or failed immediately?
(Your ORIGINAL one.) I thought it worked fine and still did, and just the new extra one didn't work or failed immediately?
Burgerman wrote:(Your ORIGINAL one.) I thought it worked fine and still did, and just the new extra one didn't work or failed immediately?
Meaning the answer was yes.And you wrote a book.
Stop stressing about that message. It means nothing. And refers to a PREVIOUS time you used the charger anyway...
steves1977uk wrote:Imagine expresso writing a book BM, he'd fill an entire library![]()
Burgerman wrote:It would never end.
Shirley http://uk.rs-online.com/web/p/pcb-conne ... s/4766833/ correct part
Burgerman wrote:I still have 3 here. In the hobby world things keep moving on though. People always want more/better/faster. One of the things that makes the PL8 fast is the 1A balance power. And the fact that it begins balancing lipo packs from any voltage. So they end fast, and you are back in the air. Even on LiFe packs, it helps to balance faster, and esp on big packs like we use. So 1A instead of 300mA and start sooner. But not lower than 3.4V.
Users browsing this forum: emilevirus, slomobile and 136 guests
