Updated:  06-Apr-10
Powerchair Battery SOC Chart  - How to check the state of charge of your powerchair batteries!
Want to know how deeply you are actually discharging your Powerchair Batteries?
Its easy, and you can do this yourself daily.  Its very important to know for a number of reasons.
Detailed PowerChair ONLY Menu
First of all you only need two things. Knowledge (on this page) and a Digital Volt Meter.
These are available if you don't have one in many places including eBay.
All it needs to do is read VOLTS accurately.
The batteries in your wheelchair are 12v Lead Acid Deep Cycle batteries. In about 99 percent of all current powerchairs. They are generally wired in pairs, and connected in series.
The chart below will apply to ONE battery only! You will need to double those voltage figures if you measure both batteries together Obviously.
Now how do you measure these voltages? And When?  Well to begin with you will need to switch OFF your Powerchair and wait at least 4 hours to get a true reading.
Overnight is better still. You cannot get very accurate reading just after charging or using your Powerchair. The voltage has to "settle" or "stabilise" so you just have to wait!  Although after say 30 minutes or so after you arrive home you will often get a reasonable idea.  With this in mind, how do you do a quick and dirty "read"?
Take a look at your powerchairs charge socket. In most modern powerchairs it generally has three holes for the "pins" in your chargers plug.
Two of these connect directly to the wheelchairs batteries. The third you can ignore.  It is used in programming, and inhibiting your chairs movement while charging.
The two we want are generally the bottom two. If you carefully stick the Volt meter probes into these two holes then it will read the true battery voltage.
 It will be about 24v to 27v.  If you have it connected backwards it will read minus this amount!  If you connect to the wrong pin it will read nothing, or a strange figure, but wont hurt anything.
Then see the chart below.  You will need to half your measured figure as you are measuring a pair of batteries connected in series or in line.
Do not let the two probes touch each other as that will cause a big bang and melt or damage something! Be careful. Read my Disclaimer!
Failing this, just read the voltage directly from the battery, individually - but that means accessing them. Not so easy!
Approx State Of Charge Chart for Wheelchair (Powerchair) DEEP CYCLE batteries
State of Charge Sealed or Flooded Lead Acid Volts Sealed Gel battery Volts Sealed AGM battery Volts Result on longevity
100% 12.70+ 12.90+ (Usually 13.2) 12.80+  (Usually 12.9) Very Long life!!!
75% 12.40 12.70 to 12.85 12.60 Many 1000's of Cycles
50% 12.20 12.40 to 12.50 12.30 Around a 1000 Cycles
25% 12.00 12.20 to 12.30 12.10 200 to 400 Cycles
0% 11.80 11.9 to 12.00 11.90 Few Tens of Cycles
Note.  When many batteries (especially Gel) get to the lower 50 percent charge level, performance, acceleration, ability to steer or climb ramps is diminished and the battery "feels" flat.  This applies mostly to Gel, and to higher powered "faster" powerchairs. It means that the last part of the batteries actual capacity is not actually usable.  In this way they tend to last longer since they seldom get discharged as deeply.  AGM batteries though offer superior performance on hi end powerchairs because they suffer less from this effect. So a nominally "smaller" capacity battery has equal or better range.
