Updated:  26-Jan-10
Powerchairs & Rain...
Is it OK to drive an electric wheelchair (Powerchair) in the rain?
Or to wash it with a bucket of soapy water and a hose pipe?
Detailed PowerChair Related ONLY Menu
I use my PowerChair outside in all weathers every single day of the year.
The dog has to be walked!  I have to go about my daily business.
If I leave the pub at midnight in my powerchair I have no choice but to go home! I just use an umbrella!
Rain isn't an issue MOST of the time.  I even wash my powerchair in my shower room at home twice a week or so using a hand held electric power shower.
Modern powerchair control systems, motors and batteries are all pretty well protected from rain and water.
So the short answer is try to keep the joystick pod from getting soaked if possible but otherwise don't worry!
One thing (component) at a time:
Powerchair Motors. These sit very low down on most powerchairs and are going to get wet if you drive in the rain. For what its worth they will actually run pretty well submerged completely under water. But splashed and wet on the outside is no concern.
They will not break down or fail just because of ANY amount of water - even under water. They use only 24 volts (on the majority of power chairs) which is not enough to cause any problems with water at all. And you cant get a shock or be electrocuted!
Water can get into bearings and cause internal corrosion problems at a later date if you go through deep puddles fast. Especially in winter if you drive on "treated" pavements and roads. Salt causes corrosion. So water in summer is less of an issue.
Salt causes masses of corrosion problems with cars, wheelchairs and everything else mechanical! But we are talking about rain or a quick rinse clean with a bucket and sponge here!
So no problem! They are very splash proof and designed to be used outdoors in the rain. Avoid deep puddles if it worries you!  Personally I just take no notice and go about my business normally.
Wiring and Batteries. Batteries are normally Gel and "sealed" so are definitely rain, splash and "wash" proof!
They CAN draw some water in if submerged under extreme circumstances, but that's not going to happen unless you drive in 12 inches of water or more!  And you have bigger problems by then!  So no worries here and wiring is waterproof although corrosion from the winter salt can cause problems after many years if you are very unlucky... But again don't worry they are designed for outdoor use.
That mysterious "controller box" power module (and lighting/seat actuator etc under the seat).  These are not waterproof. But its not likely in a modern powerchair that the rain can get at them even during a hurricane!  They should be in a safe spot that stays dry. Even so they are fairly splash resistant. But a hose potentially could get water inside one. A shower like the one I use cant actually reach the controller very easily and a few minor splashes are not a problem anyway.
 So if you rinse your powerchair with a hose don't aim it under the seat or at where these components live.  Other than that again don't worry!
Joystick & housing (pod) This is the one bit that IS vulnerable in rain. Light rain? Again don't worry. Heavy rain for a couple of minutes while you dash home still no problem. But out in the rain for long periods and you should worry!
If rain gets in (or my water from the shower) then it usually results in an error and no go! Typically no serious damage but strange errors and you may be stranded.  If you leave it for a while or even a day it will likely dry out and be just fine. Mine always is.
Simple precaution, just keep a plastic bag under your seat cushion or somewhere just in case you get caught out in heavy rain. Or call into a shop and scrounge a plastic bag. Just pop it over the entire pod for protection. Then drive normally while you drown.  Its not a problem in light rain/short periods. In heavy rain and for long periods its not a problem either provided the joystick pod is protected with a plastic bag.
